I am trying to add a WebHierarchicalDataGrid and HeirachicalDataSource to my web page. With the exception of the DataGrid, which errors with an abmigous error when added from the toolbox I get the following error on compile (I suspect the latter issue is tied to this):
The type 'Infragistics.Web.UI.DataSourceControls.DataView' exists in both 'c:\Windows\assembly\GAC_MSIL\Infragistics35.Web.v11.2\11.2.20112.1019__7dd5c3163f2cd0cb\Infragistics35.Web.v11.2.dll' and 'c:\Windows\Microsoft.NET\assembly\GAC_MSIL\Infragistics4.Web.v11.2\v4.0_11.2.20112.1019__7dd5c3163f2cd0cb\Infragistics4.Web.v11.2.dll'
How can this be resolved?
Hello Richard,
We have discussed and resolved this over the phone. So other may benefit from this I am going to post the answer here as well. As we discussed this issue was happening because two CLR versions of the assemblies were being referenced in the same project. The way you can check for this is to check your aspx and Web.config files of your website and check the version of the assemblies referenced. The most likely reason why this occurred is that when the controls were dragged from the Visual Studio toolbox there were multiple versions grabbed. To resolve this I had you delete the tab in the toolbox and use the Create toolbox tab utility.
Sincerely,Mike P.Developer Support EngineerInfragistics, Inc.www.infragistics.com
