Could I get some code examples of how to keep what rows are expanded and collapse in an UltraWebGrid after a postback? My grid is grouped by a column and is initially collapsed on load, buth then the users expand. After updating a record using a rowedittemplate, the grid is reloaded, but loses what rows are expanded and collapsed. I'd like to reload the grid then put it back the way it was before the postback.
Hello Will Larkin ,
Thank you for sharing your solution.
Let me know if I can further assist you with this issue.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
Maya, I ended up going about it a pretty harsh way to keep from rewriting everything I had to move it to the server side. It would have worked better, but the users have different ways to update a record. Biggest hurdle I had to get through was when enough rows are updated a group was completely removed from the grid. I had to get away from using the rowId because of this. I'm awaiting the users approval as this way adds seconds to the grid rerendering and slows the app down.
I call getExpandedRows on RowEditTemplate close event and setExpandedRows on InitializeLayoutHandler event of the grid.
function getExpandedRows() { var grid = igtbl_getGridById('uwg_pending'); var expRows = grid.ExpandedRows; var hidden = document.getElementById("hiddenField1"); hidden.value = ""; for (var i in expRows) { var row = igtbl_getRowById(i); var datak = (row.DataKey == "" ? datak = "X" : datak = row.DataKey); hidden.value += i + "|" + row.Value + "~" + datak + ","; } }
function setExpandedRows() { var grid = igtbl_getGridById('uwg_pending'); var hidden = document.getElementById("hiddenField1"); if (hidden.value != "") { var rowsToExpand = hidden.value.split(","); var oRows = grid.Rows; var numRows = 0; for (var i = 0; i < oRows.length; i++) { var lenExpandRows = rowsToExpand.length; if (numRows == lenExpandRows - 2) { return } oRow = oRows.getRow(i); oRow.setExpanded(true); if (oRow.ChildRowsCount > 0) { var oChildRows = oRow.Rows; if (lenExpandRows != 1) { for (var k = 0; k < lenExpandRows - 1; k++) { var rowDetail = rowsToExpand[k].split("|"); var rowData = rowDetail[1].split("~"); if (rowData[1] != "X" && rowData[1] == oRow.Value) { for (var j = 0; j < oChildRows.length; j++) { oChildRow = oChildRows.getRow(j); if (oChildRow != null) { if (oChildRow.Value == rowData[0] && oChildRow.DataKey == rowData[1]) { oChildRow.setExpanded(true); numRows++; break; } } } } } } } var expand = 0; for (var j = 0; j < oChildRows.length; j++) { oChildRow = oChildRows.getRow(j); if (oChildRow != null) { if (oChildRow._Changes.ExpandedRows != null) { expand++; } } } if (expand == 0) { oRow.setExpanded(false); } } } hidden.value = ""; }
Hello Will Larkin,
I'm just following up to see whether you need further assistance with this issue.
If so please let me know.
In this case a server side approach would be better.
For example you could handle the ExpandRow server side event.It will fire each time you expand any row. From there you can get the currently expanded row with e.Row.
You can get all the rows specifications you need so that you can find it and expand it later. Then in the UpdateRow event you can just get that row and call its expand method.
In this way you shouldn’t encounter a significant performance issue.
Let me know if I can further assist you in any way.
I'm still trying to get this to work. Your suggestion of the ChildRows works great, as long as the row still exists after the databind. If the row that was expanded gets removed after the server side databind, it expands the next row below, as that row now has the saved RowID. I'm trying to now expand based on data in the groupby row instead of the RowID to solve this issue.
I'm having to iterate through the 1st level groups, then iterate through the 2nd level groupby rows, and compare each 2nd level groupby row to each value in the saved expanded list until a match is found. It's really slowing down the app, so I'm probably going to have to scrap it.
