I have a WebDatGrid which contains data fields with HTML codes. The grid displays these codes correctly. However after a row updating where an item is selected that contains HTML codes, the grid display does not show the symbol, instead it displays the code.
Can anyone help me!
Hello gsashev,
Thank you very much. It works.
Hello lcarneiro,
Here you can find attached a sample code that is according to your scenario. I tested this and it seems to behave as expected. After updating the grid still shows the correct symbols. You can review the sample and let me know if you have any questions.
If I misunderstood your scenario, please update the sample.
I hope this helps.
For any further questions do not hesitate to contact me.
Sincerely,
Georgi Sashev
Developer Support Engineer
Infragistics, Inc.
