I'm using 2010 v3, CLR35. I'm testing to offer support for Chrome. In Chrome, when I add an appointment the form comes up ok, but the Save and Recurrence do nothing when I click on them. Nothing is inserted into the database, and the window doesn't close. I've noticed that instead of text in the two buttons, it's a hyperlink.
I've attached a screen shot. Does anyone know what might be causing this?
Hi Scott,
I have created a case on your behalf and we can continue our communication through the support ticket. It`s number is - CAS-80136-89PX2W.
Thank you for choosing Infragistics.
Sincerely,
Georgi Sashev
Developer Support Engineer
Infragistics, Inc.
Georgi,
I tried the sample, and it has the same issue (text on the buttons is also a hypertext). However, when I try it with IE I have the same problem (clicking on the Add button in the appointment window does nothing). I can't actually add a record in either Chrome or IE. However, are the samples supposed to allow an actual add or edit?
Hello Scott,
Thank you for posting in our community. Can you try to go to our online samples:
http://samples.infragistics.com/aspnet/Samples/WebSchedule/Display/FullPageSample/Default.aspx?cn=schedule&sid=205dc314-a141-40a4-85b6-9ff84b53532d
Here and test this sample with the WebSchedule.
Please make sure that the popup blocker allows appointments.
Let me know the results of your tests.
