435
Get a column name from grid with multi-coulmn headers
Im trying to get the values for sub columns in multi-column header grid.The markup is my grid below. I need to get teh value for "Q1Var".
Using this code in Initialize_Row says it cant find "Q1Var".  Seems like It finds "QTR1" but not it sub columns.
e.Row.Items(Me.WdgCurrYear.Column("Q1Var").Index).Text =
        NumberFormatting.FormatData(e.Row.Items(Me.WdgCurrYear.Column("Q1Var").Index).Text, False, 2, True)
I will need to use this when they submit too.  So a way to access these columns would be appreciated
<ig:WebDataGrid ID="WdgCurrYear" runat="server" AutoGenerateColumns="False" StyleSetName="WestonBlue">
            <Columns>
                <ig:BoundDataField DataFieldName="FY_CD" DataType="System.String" Hidden="True" Key="FY_CD">
                    <Header Text="YEAR" />
                </ig:BoundDataField>
                <ig:BoundDataField DataFieldName="METRIC_ID" Hidden="True" Key="METRIC_ID">
                    <Header Text="Metric ID" />
                <ig:BoundDataField DataFieldName="METRIC_DESC" Key="METRIC_DESC">
                    <Header Text="Metric" />
                <ig:GroupField Key="QTR1"  Header-CssClass="Multi_Col1">
                    <Header Text="Q1" />
                    <Columns>
                        <ig:BoundDataField DataFieldName="Q1Plan" Key="Q1Plan" Header-CssClass="Single_Col" CssClass="igg_WestonBlueItemRAlign">
                            <Header Text="Plan" />
                        <ig:BoundDataField DataFieldName="Q1amt" Key="Q1amt" Header-CssClass="Single_Col_Bot" CssClass="igg_WestonBlueItemRAlign">
                            <Header Text="Amt" />
                        <ig:BoundDataField DataFieldName="Q1Var" Key="Q1Var" CssClass="DisableRow igg_WestonBlueItemRAlign" Header-CssClass="Single_Col_Bot" >
                            <Header Text="Var" />
                            <Footer CssClass="Class1" />
                    </Columns>
                </ig:GroupField>
                <ig:GroupField Key="QTR2"  Header-CssClass="Multi_Col1">
                    <Header Text="Q2" />
                    <Columns>
                        <ig:BoundDataField DataFieldName="Q2Plan" Key="Q2Plan" Header-CssClass="Single_Col" CssClass="igg_WestonBlueItemRAlign">
                        <ig:BoundDataField DataFieldName="Q2amt" Key="Q2amt" Header-CssClass="Single_Col_Bot" CssClass="igg_WestonBlueItemRAlign">
                        <ig:BoundDataField DataFieldName="Q2Var" Key="Q2Var" CssClass="DisableRow igg_WestonBlueItemRAlign" Header-CssClass="Single_Col_Bot">
                </Columns>
                </ig:GroupField>
                <ig:GroupField Key="QTR3"  Header-CssClass="Multi_Col1">
                    <Header Text="Q3" />
                    <Columns>
                        <ig:BoundDataField DataFieldName="Q3Plan" Key="Q3Plan" Header-CssClass="Single_Col" CssClass="igg_WestonBlueItemRAlign">
                        <ig:BoundDataField DataFieldName="Q3amt" Key="Q3amt" Header-CssClass="Single_Col_Bot" CssClass="igg_WestonBlueItemRAlign">
                        <ig:BoundDataField DataFieldName="Q3Var" Key="Q3Var" CssClass="DisableRow igg_WestonBlueItemRAlign" Header-CssClass="Single_Col_Bot">
                    </Columns>
                </ig:GroupField>
                <ig:GroupField Key="QTR4"  Header-CssClass="Multi_Col1">
                    <Header Text="Q4" />
                    <Columns>
                        <ig:BoundDataField DataFieldName="Q4Plan" Key="Q4Plan" Header-CssClass="Single_Col" CssClass="igg_WestonBlueItemRAlign">
                        <ig:BoundDataField DataFieldName="Q4amt" Key="Q4amt" Header-CssClass="Single_Col_Bot" CssClass="igg_WestonBlueItemRAlign">
                        <ig:BoundDataField DataFieldName="Q4Var" Key="Q4Var" CssClass="DisableRow igg_WestonBlueItemRAlign" Header-CssClass="Single_Col_Bot">
                    </Columns>
                </ig:GroupField>
                <ig:GroupField Key="Year"   Header-CssClass="Multi_Col2">
                    <Header Text="Year" />
                    <Columns>
                        <ig:BoundDataField DataFieldName="YrPlan" Key="YrPlan" CssClass="DisableRow igg_WestonBlueItemRAlign" Header-CssClass="Single_Col">
                        <ig:BoundDataField DataFieldName="YrAmt" Key="YrAmt" CssClass="DisableRow igg_WestonBlueItemRAlign" Header-CssClass="Single_Col_Bot">
                        <ig:BoundDataField DataFieldName="YrVar" Key="YrVar" CssClass="DisableRow igg_WestonBlueItemRAlign" Header-CssClass="Single_Col2">
                    </Columns>
                </ig:GroupField>
                <ig:BoundDataField DataFieldName="COMMENT" Key="COMMENT">
                    <Header Text="Comments" />
                <ig:BoundDataField DataFieldName="Calculation" Hidden="True" Key="Calculation">
                    <Header Text="Calculation" />
            </Columns>
            <Behaviors>
                <ig:EditingCore>
                    <Behaviors>
                        <ig:CellEditing>
                            <ColumnSettings>
                                <ig:EditingColumnSetting ColumnKey="Q1Var" ReadOnly="True" />
                                <ig:EditingColumnSetting ColumnKey="Q2Var" ReadOnly="True" />
                                <ig:EditingColumnSetting ColumnKey="Q3Var" ReadOnly="True" />
                                <ig:EditingColumnSetting ColumnKey="Q4Var" ReadOnly="True" />
                                <ig:EditingColumnSetting ColumnKey="YrPlan" ReadOnly="True" />
                                <ig:EditingColumnSetting ColumnKey="YrAmt" ReadOnly="True" />
                                <ig:EditingColumnSetting ColumnKey="YrVar" ReadOnly="True" />
                                <ig:EditingColumnSetting ColumnKey="METRIC_DESC" ReadOnly="True" />
                            </ColumnSettings>
                            <EditModeActions MouseClick="Single" />
                            <CellEditingClientEvents EnteringEditMode="WebDataGridView_EnteringEditMode" />
                        </ig:CellEditing>
                    </Behaviors>
                </ig:EditingCore>
            </Behaviors>
        </ig:WebDataGrid>
Steve Zelonis
