I have a line chart with data points that are squares. I would like to make it so if a data point value is above let's say 25 then the square changes color to red, if it is below 25 then change the square's color to green.
I have accessed the ChartDrawItem and looped through the Primitives. I found the PointSet Primitive with the DataPoints and the icon value. However, nothing I change in the DataPoints PE affects the icon color and when I change the icon values for the PointSet it effects all points.
Is it possible to change color, icon, etc. for a single point on a line?
Hello Petar, how can i implement the FillSceneGrahp method that you sample as an example with all the code ? ima little bit confused
That did the trick, thanks.
Hi kywoo916,
You can style the datapoints in a line chart differently by handling the FillSceneGraph event. A very similar scenario is discussed in the following thread:
http://blogs.infragistics.com/forums/p/33056/180939.aspx#180939
The difference is that in your scenario you should handle the DataPoints in a Polyline primitive. Here is a sample implementation for styling the odd and even indexed datapoints on a single line with different colors.
protected void UltraChart1_FillSceneGraph(object sender, Infragistics.UltraChart.Shared.Events.FillSceneGraphEventArgs e) { PrimitiveCollection symbols = new PrimitiveCollection(); foreach (Primitive p in e.SceneGraph) { Polyline polyline = p as Polyline; if (polyline != null) { //this index is used to style even and odd indexed points on a polyline differently.polyline.Value can be checked instead. int index = 0; foreach (DataPoint dataPoint in polyline.points) { Symbol symbol = new Symbol(); symbol.icon = SymbolIcon.Circle; symbol.iconSize = SymbolIconSize.Medium; if (index % 2 == 0) { symbol.PE.Fill = Color.Red; index ++; } else { symbol.PE.Fill = Color.Green; index++; } symbol.point = dataPoint.point; symbols.Add(symbol); } } } e.SceneGraph.AddRange(symbols.ToArray()); }
Please let me know if this helps.
