126
Problem with the client ItemClick in the WebDataMenu when set_cancel is true
Hello, I've a problem with the cancel event in the WebDataMenu.
I've a WebDataMenu as a context menu in a WebDataTree. In some of the menu items I want to make actions in client. In other items I want to execute the server handler.
With the server action there is no problem, but if I cancel the postback once, the client handler doesn't work for this item any more.
You can try this sample:
The first time I click in the first item I see the message, but if I click again it doesn't work, if I click in the second item there is no problem.
            <ig:WebDataMenu runat="server" ID="WebDataMenu1" IsContextMenu="true" Style="display: none;"
                OnItemSelected="WebDataMenu1_ItemSelected">
                <AutoPostBackFlags ItemClick="Off" ItemSelected="On" />
                <ClientEvents ItemSelected="WebDataMenu1Client_ItemClick" />
                <GroupSettings AnimationType="ExpandAnimation" Orientation="Vertical" />
                <Items>
                    <ig:DataMenuItem Text="No Postback" Key="Np">
                    </ig:DataMenuItem>
                    <ig:DataMenuItem Text="Postback" Key="Yp">
                    </ig:DataMenuItem>
                </Items>
            </ig:WebDataMenu>
function WebDataMenu1Client_ItemClick(sender, e) {
        var itemMenu = e.getItem();
        switch (itemMenu.get_key()) {
            case "Np":
                    alert("No Postback");
                    e.set_cancel(true);
                    break;
            case "Yp":
                    alert("Yes, Postback!");
                    e.set_cancel(false);
                    break;
