1360
Images Only
Is it possible to get rid of all of the WebImageViewer controls, borders, backgrounds and so on so that only the image is displayed?
i have tried the following (in the .ASPX declarations):
BorderWidth = "0"
BorderStyle="None"
EnableTheming="False"
Width="800"
Height="187"
And in Code:
WebImageViewer1.BorderStyle = BorderStyle.None;
WebImageViewer1.Header.Visible = false;
WebImageViewer1.Footer.Visible = false;
WebImageViewer1.NextButton.Visible = false;
WebImageViewer1.PreviousButton.Visible = false;
WebImageViewer1.ControlStyle.BorderStyle = BorderStyle.None;
WebImageViewer1.ControlStyle.BorderWidth = 0;
WebImageViewer1.ControlStyle.BackColor = Color.Red;
Setting the Backgroundcolour to red shows me that the control is bigger than I have declared it to be, it is 235 pixels high rather than the 187 that I have declared.
I have attached three images showing 1) the effect that I want (just the image and nothing else - the control is set using a timer to scroll vertically through a number of images automatically and I neither want nor need user interaction), and 2) the result of my experiments so far by setting available control settings. 3) The result of setting StyleSetName=" " in the Control declaration - in this instance the control has the correct dimensions, as shown by the red background, but the images are way too small and in the wrong place. The application style="Pear".
Looks like it could be a StyleSet problem but I have no idea how to fix it quickly and efficiently
Any help would be gratefully received.
Kind regards,
Paul
IG for ASP.NET 2011.2, CLR4, VS2010, WebViewer: 11.2.20112.1019
  • 8160
    Hello Paul,
    could you try to remove padding from ig_imageViewer.css:
    /* The CSS Class that will be applied to the outer control.*/
    .igiv_PearControl
    background-color:Transparent
    /*padding-bottom: 50px;
    padding-left:20px;
    padding-right: 20px;*/
