I'm trying to align check boxes centered in the cell, and Dollars right aligned.
<ig:BoundDataField DataFieldName="PaymentAmount" Key="PaymentAmount" Width="125px" DataFormatString="{0:$ #,##0.00}" CssClass="AlignRight"> <Header Text="Amount" /></ig:BoundDataField>
This looks like the example, but I'm missing something, any ideas?
Chuck
Hello csnyder_ptb,
Please make sure that the setting you set in the custom class for the column -AlignRight are not getting overwritten by the default css classes.
You can do that by setting the !important tag after the setting. For example:
.AlignRight
text-align: right !important;
I’m attaching a sample with the behavior you’ve described. Let me know if you have any further questions or concerns regarding this issue.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
Thanks, that solved the problem.
