45
What can i do, for "node" -> "attribute manipulation" with javascript
I want to add a attribute (for example title="UID"... ) to the new node, but it dosen't work.
I need the title attribute, because in my project there are 3 Typs off nodes:
1. K_56gS5sa  K_ = Typ = Catalog
2. C_ HG52s2 C_ = Typ = Category
3. P_65jgsG4  P_ = Typ = Product
 I want to manipulation attributes or set new attributes of a new node.
Here the example Code:
<asp:UpdatePanel ID="UpdatepanelTreeview" runat="server" UpdateMode="Conditional"
          ChildrenAsTriggers="true">
          <ContentTemplate>
  <ig:WebDataTree ID="DDWebDataTree" runat="server" StyleSetName="RedPlanet"
              SelectionType="Single"
              EnableAjax="true"
              CheckBoxMode="Off"
              EnableConnectorLines="true"
              EnableAutoChecking="true"
              EnableAjaxViewState="true"
              OnNodeDropped="DDWebDataTree_NodeDropped"
              OnNodeClick="DDWebDataTree__NodeClick"
              ClientEvents-DragStart="GetParent"
              NodeSettings-ParentNodeImageUrl="~/theme/images/tools/catalog.png"
              NodeSettings-LeafNodeImageUrl="~/theme/images/tools/category.png"
              NodeSettings-ImageUrl="~/theme/images/tools/product.png"
              DataLoadingMessage="...loading"
              ViewStateMode="Enabled" >
              <DragDropSettings AllowDrop="true" EnableDragDrop="true">
              </DragDropSettings>
              <AutoPostBackFlags
                NodeDropped="On"
                NodeAdded="On"
                NodeRemoved="On"
                NodeClick="On"
                NodeEditingTextChanged="On" />
            </ig:WebDataTree>
            <asp:HiddenField ID="HF_Parent" runat="server" Value="" />
          </ContentTemplate>
          <Triggers>
            <asp:AsyncPostBackTrigger ControlID="DDWebDataTree" />
          </Triggers>
        </asp:UpdatePanel>
<script>
function addNode(sUID, sName, iTyp) {
  //var nodeText = textBoxNewNode.value;
  var nodeText = sName;
  textBoxNewNode.value = "";
  if (isNullorUndefined(nodeText) || (nodeText == "")) {
    alert("You have to specify a node name.");
    return false;
  var parent = currentTree.get_selectedNodes();
  var location;
  if ((!isNullorUndefined(parent)) && (parent.length > 0)) {
    location = $adrutil.getLocationFromDomElement(parent[0].get_element());
  var node = currentTree.createNode(nodeText);
  node.set_valueString(sUID);
  node.set_id(sUID);
  //node.setAttribute("title", sUID);
  node._element.setAttribute("title", sUID)
  if (!isNullorUndefined(location)) {
    currentTree.add(node, location);
  else {
    currentTree.add(node, null);
