410
Came across a bug.
I was trying to fill the WebDropDown with a JSON WebService. I have implemented the code and when I run the program I came across with an exception in IG scripts and on top of the exception following message exists.
K.D. June 27th, 2011 Bug #75499, the template was not properly retrieved when set by the client.
But I am still getting an exception from
$.tmpl(template, item) ... line.
Can you please help me if the bug still exists or may be I am not setting webdropdown correctly.
Note that following are set in client
1. Enable Client Rendering true
Cheers
