1805
Web Service Error
Folks,
I have published a web service on IIS 7 on Windows 2008 R2 Server, which is inside my default website folder. Has nothing to do with Infragistics dll's.
http://MyServerName/ADService
I also tried to place it outside on different drive on server but still getting the following error.
Picture displays the server file structure
 Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IO.FileNotFoundException: Could not load file or assembly 'Infragistics4.WebUI.Shared.v11.2, Version=11.2.20112.2025, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Assembly Load Trace: The following information can be helpful to determine why the assembly 'Infragistics4.WebUI.Shared.v11.2, Version=11.2.20112.2025, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' could not be loaded.
WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Stack Trace:
[FileNotFoundException: Could not load file or assembly 'Infragistics4.WebUI.Shared.v11.2, Version=11.2.20112.2025, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.] System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks) +0 System.Reflection.RuntimeAssembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks) +39 System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection, Boolean suppressSecurityChecks) +132 System.Reflection.RuntimeAssembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +144 System.Reflection.Assembly.Load(String assemblyString) +28 System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +46 [ConfigurationErrorsException: Could not load file or assembly 'Infragistics4.WebUI.Shared.v11.2, Version=11.2.20112.2025, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.] System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +618 System.Web.Configuration.CompilationSection.LoadAssembly(AssemblyInfo ai) +57 System.Web.Compilation.BuildManager.GetReferencedAssemblies(CompilationSection compConfig) +178 System.Web.Compilation.BuildManager.GetPreStartInitMethodsFromReferencedAssemblies() +94 System.Web.Compilation.BuildManager.CallPreStartInitMethods() +332 System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters, PolicyLevel policyLevel, Exception appDomainCreationException) +677 [HttpException (0x80004005): Could not load file or assembly 'Infragistics4.WebUI.Shared.v11.2, Version=11.2.20112.2025, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.] System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +9087676 System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +97 System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +256
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.272
Server Error in '/ADService' Application.
