I'am trying to add a new row to the child grid and I get "Element cannot be undefined" exception.
1. WebHierarchicalDataGrid has 2 levels of data.
2. BatchUpdating is on. (it's important, if it is off - works fine)
3. AddingRow behaviour has been added.
4. I enter some values for a new row and press 'Enter' after that the error appears
Please check is it a real bug or I do something wrong.
Alexander
Hi, David!
David, thank you for your help,
maybe you can look at this problem, it is about keep expanded rows after postback. I think it is quite standard scenario.
http://community.infragistics.com/forums/p/65316/330746.aspx#330746
Thank you for help!
Hello Alexander,
I have created private support case CAS-83631-NSWZMZ for you. I will link this support case to development issue 101084.
As per my understanding, the next service release for ASP.NET is projected on March 8th. Refer to the link below that will give more details on this:
<http://ko.infragistics.com/support/service-releases.aspx#ServiceReleases>
I will update the support case CAS-83631-NSWZMZ for future updates.
Hi Alexander,
I am not sure of the exact date, but I would assume it to be sometime in February. It is usually slightly dynamic as last minute fixes get in or if testing is completed sooner. I would contact Developer Support so that you can be appraised of exactly when the SR ships with this fix.
-Dave
Hi, David! Thank you, And what's the date of next Service Release? Alexander
