Processing event on the server with
ContainerGrid g = (ContainerGrid) sender ; int b = (int)g.Rows.Count;
from here :
a. How to scan efficiently through every row, seems like foreach not working
b. If I need to find particular row in the grid, by using known value of keyfield is any other way then scanning through every row.
thanks
re: Am I right?Yes you are, indeed. But I found it later, at the time of post I've got an error that some enumerator not implemented.... I did something wrong.....anyway what about question #2 it still open :b. If I need to find particular row in the grid, by using known value of key field or other fieldis any other way then scanning through every row.e.g. in the same setting : ContainerGrid g = (ContainerGrid)sender; how I would search for particular raw with some value without scanning.I did not see any Find or something method.Thanks
Hi mcseidel,
As far as I can see from your sample in this post http://community.infragistics.com/forums/t/65466.aspx
you have managed to itterate through grid's rows.
Am I right?
1. RowUpdating
2.
<ig:WebScriptManager ID="igwsm" runat="server"> </ig:WebScriptManager> <ig:WebHierarchicalDataGrid ID="whdg" runat="server" AutoGenerateColumns="False" DataKeyFields="idMaster" Height="373px" Key="idMaster" Width="1040px" onrowislandspopulating="whdg_RowIslandsPopulating" oncalculatecustomsummary="whdg_CalculateCustomSummary" onrowupdating="whdg_RowUpdating"> <Columns> <ig:BoundDataField DataFieldName="idMaster" DataType="System.Int32" Key="idMaster"> <Header Text="idMaster" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Account" DataType="System.String" Key="Account"> <Header Text="Account" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Description" Key="Description"> <Header Text="Description" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="Amount" DataType="System.Int64" Key="Amount"> <Header Text="Amount" /> </ig:BoundDataField> </Columns> <Behaviors> <ig:EditingCore EnableInheritance="true" AutoCRUD="False"> <Behaviors> <ig:CellEditing EnableInheritance="true"> <EditModeActions MouseClick="Single" /> </ig:CellEditing> </Behaviors> </ig:EditingCore> <ig:SummaryRow AnimationEnabled="True" EmptyFooterText="-No- " FormatString="Overall Balance : ${1}" ShowSummariesButtons="False" SummariesCssClass="Summary01" EnableInheritance="True" > <ColumnSummaries> <ig:ColumnSummaryInfo ColumnKey="Amount"> <Summaries> <ig:Summary CustomSummaryName="Cust01" SummaryType="Custom" /> </Summaries> </ig:ColumnSummaryInfo> </ColumnSummaries> <%-- <ColumnSettings> <ig:SummaryRowSetting ColumnKey="Amount" ShowSummaryButton="False" FormatString="AUX : {1}" EnableColumnSummaryOptions="False"> <SummarySettings> <ig:SummarySetting CustomSummaryName="Alibaba" SummaryType="Sum" /> </SummarySettings> </ig:SummaryRowSetting> </ColumnSettings>--%> </ig:SummaryRow> <ig:Activation> </ig:Activation> </Behaviors> </ig:WebHierarchicalDataGrid>
When you are trying to get the rows count? Can you post the grid's markup?
Thank you
