80
DataWebGrid- Clicking on row selector throws an error
I am using Infragistics webdatagrid v11.1.For eg: I have 3 columns id, name,gender in my webDG. When I double click on any of the rows, I want the row ID to be retrieved. I have achieved this using the below code.It works fine only if I click on the row elements. But when I dblclick on the row selector tab (leftmost) or the table header it throws a js exception( Microsoft JScript runtime error: Object doesn't support property or method 'get_row). Please help on resolving this issue.
I want to do the same function when a row is dblClicked / when row selector is dblclicked.
 <ig:WebDataGrid ID="WebDataGrid1" runat="server" Height="350px" Width="400px"
            ViewStateMode="Enabled" EnableAjax="False" ClientEvents-DoubleClick="webDataGrid_DblClick1">
Corresponding javascript function:
<script type="text/javascript" id="webGridScr">
    function webDataGrid_DblClick1(sender, eventArgs) {
         var newSelectedCell1 = eventArgs.get_item().get_row().get_cellByColumnKey("RowID").get_text();
        var newSelectedCell2 = eventArgs.get_item().get_row().get_cellByColumnKey("Name").get_text();
        alert("the value is" + newSelectedCell1 + newSelectedCell2);
        form1.submit();
</script>
  • 37874
    Hi prathi84,
    If you want to use the DoubleClick client-side event, I would suggest you to use the following code to get the value from the first cell of the selected row:
            function doubleClick(sender, eventArgs) {
                var selectedRow = sender.get_behaviors().get_selection().get_selectedRows(0);
                var IDValue = selectedRow.getItem(0).get_cellByColumnKey("ID").get_text();
                alert('The value is: ' + IDValue);
    It seems to me that there is no double click event of the row selectors. However, there is RowSelectorClicked event:
         <Behaviors>
                    <ig:RowSelectors>
                        <RowSelectorClientEvents RowSelectorClicked="rowSelectorClicked" />
                    </ig:RowSelectors>
                </Behaviors>
    And the handler should look something like the following:
            function rowSelectorClicked(sender, eventArgs) {
                var IDValue = eventArgs.get_row().get_cellByColumnKey("id").get_text();
    Please let me know if this helps.
