Hello, guys!
My host is running into a medium trust level (shared) and some components (as WebDataGrid) are working normally.
I'm having a problem with both components in the subject. When I try to load the WebDialogWindow (i.e.) I get the message below:
[No relevant source lines]
[SecurityException: Request failed.] Infragistics.Web.UI.LayoutControls.DialogWindowHeader.RenderContentsVisible(HtmlTextWriter writer) +0 Infragistics.Web.UI.LayoutControls.DialogWindowHeader.RenderContents(HtmlTextWriter writer) +327 System.Web.UI.WebControls.WebControl.Render(HtmlTextWriter writer) +32 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 Infragistics.Web.UI.LayoutControls.DialogWindowRenderer.RenderHeader(HtmlTextWriter writer) +503 Infragistics.Web.UI.LayoutControls.DialogWindowRenderer.RenderContents(HtmlTextWriter writer) +1265 Infragistics.Web.UI.Framework.RunBot.HandleRenderContents(HtmlTextWriter writer, RendererBase renderer) +154 Infragistics.Web.UI.Framework.ControlMain.RenderContents(HtmlTextWriter writer) +57 Infragistics.Web.UI.Framework.ControlMain.Render(HtmlTextWriter writer) +15 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +208 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +8 System.Web.UI.Control.Render(HtmlTextWriter writer) +10 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +208 System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) +173 System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) +31 System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) +53 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100 System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) +40 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +208 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +8 System.Web.UI.Control.Render(HtmlTextWriter writer) +10 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +208 System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +8 System.Web.UI.Page.Render(HtmlTextWriter writer) +29 System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27 System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +100 System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +8431 System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +253 System.Web.UI.Page.ProcessRequest() +78 System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context) +21 System.Web.UI.Page.ProcessRequest(HttpContext context) +49 ASP.default_aspx.ProcessRequest(HttpContext context) in c:\windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\teste\f0bf235e\70281209\App_Web_dt4npnvi.0.cs:0 System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +100 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
For the WebUpload I get the same Security Exception error (with the stack trace different).
- All assemblies are inside the bin directory.- In my local environment (VS 2010) everything is working fine.- I create a new project just with these components and the error persists.
Please, help!
Thank you in advance!
This is just to confirm that in the newer versions of NA for ASP.NET the APCTA flag is true by default in the AIKIDO assemblies, therefore the APCTA folder is missing (the regular DLLs can be used).
I have the same problem ... aptca dlls not exists in 2012.2 ..... help please
Just to tell, I still have that problem...
Thanks!
I'm encountering the same issue with a WebDialogWindow when the solution is uploaded on the ISP's hosting environment. I'm using ASP.Net 2012.2 and I cannot see the ACPTA directory, are these DLL'sd available for 2012.2?
The ISP advises Medium Trust is the maximum available.
Please advise.
Cheers
Steve Wark
Hi jugeickjr,
Please contact me if any further questions arise regarding this matter.
