105
Object reference not set to an instance of a object
Hi Team,
I am getting error "Object reference not set to an instace of a object" error when I am trying to access any control on the aspx page after adding or deleting a row from a WebDataGrid. Can somebody please let me know what might be the issue?
What is the issur in the below function?
public
void  GetDropdownCategories()
{_db =
DatabaseFactory.CreateDatabase("ISDBConnectionString");
_user =
WindowsIdentity.GetCurrent().Name;
DataSet oDs = new DataSet();
DbCommand cmd = _db.GetStoredProcCommand("usp_TSS_Category_S");
cmd.CommandType =
CommandType.StoredProcedure;
cmd.Connection = GetISDBConnection();
oDs = _db.ExecuteDataSet(cmd);
wddCategory.DataSource = oDs;
wddCategory.TextField =
"Category";
wddCategory.ValueField =
"CategoryId";
The ASPX page is shown below:
body>
<form id="form1" runat="server">
<ig:WebScriptManager ID="WebScriptManager1" runat ="server">
</ig:WebScriptManager>
<asp:UpdatePanel ID="up1" runat="server">
<ContentTemplate>
<!--#BEGIN SNIPPET#-->
<asp:ObjectDataSource ID="objCategory" runat="server"
SelectMethod="GetCategories"
UpdateMethod
="UpdateCategory"
InsertMethod
="AddCategory"
DeleteMethod="DeleteCategory"
TypeName
="TechnologyServies.Maintenance.ApplicationService">
<UpdateParameters
<asp:Parameter Name="categoryId" Type="String" />
<asp:Parameter Name="category" Type="String" />
</UpdateParameters
<InsertParameters
</InsertParameters
<DeleteParameters
</DeleteParameters
</asp:ObjectDataSource>
<table
<tr
<td
<asp:Label ID="lblCategoryStatus1" runat="server" SkinID="h6" Text="Test" ></asp:Label
</td
</tr
<tr>
<td
<ig:WebDataGrid ID="wdgCategory" runat="server"
AutoGenerateColumns="false" DataSourceID="objCategory" DataKeyFields="CategoryId" Width="350px" >
<Behaviors
<ig:Activation/>
<ig:EditingCore Enabled="true" AutoCRUD
="true">
<Behaviors
<ig:RowAdding
<ColumnSettings
<ig:RowAddingColumnSetting ColumnKey="CategoryId" ReadOnly="true"
</ColumnSettings
<AddNewRowClientEvents
</ig:RowAdding>
<ig:RowDeleting
<ig:CellEditing
<ColumnSettings
<ig:EditingColumnSetting ColumnKey="CategoryId" ReadOnly="true"
</ColumnSettings
</ig:CellEditing
</Behaviors
</ig:EditingCore
<ig:ColumnFixing
<ig:ColumnMoving
<ig:ColumnResizing
<ig:Paging PageSize
="5"/>
<ig:Selection CellClickAction="Row" RowSelectType="Multiple" ColumnSelectType
="Multiple"/>
<ig:RowSelectors RowNumbering="true"
</Behaviors>
<Columns
<ig:BoundDataField DataFieldName="CategoryId" Key="CategoryId" Header-Text="Category Id" Width
="90px"/>
<ig:BoundDataField DataFieldName="Category" Key="Category" Header-Text="Category" Width="150px"
</Columns
</ig:WebDataGrid>
</td
</tr
</table>
</ContentTemplate
</asp:UpdatePanel
<!--#END SNIPPET#-->
<div style="border-left: 0px; padding: 0px; width
: 350px">
<asp:Button ID="btnSaveData" ClientIDMode="Static" runat="server" CssClass="batch-buttons" Text="Save Category"
<!--<asp:Button ID="btnDefaultData" runat="server" CssClass="batch-buttons" Text="Cancel" CommandName="Cancel" /> -->
</div
<div
<table>
<tr
<td
<asp:Label ID="lblCategory" runat="server" Text="Category" SkinID="h4"></asp:Label> </td
<td>
<ig:WebDropDown ID="wddCategory" runat="server" Width="200px" CurrentValue="Select Category"
DropDownContainerWidth="300px" >
</ig:WebDropDown
</td
</tr
</table
</div>
</form
body>
pufftuff
Parents
  • 49378
    Hi pufftuff,
    From what I can see in your code WebDataGrid is inside an updatePanel. I suggest that you try disabling the grid's AJAX in order to check if that makes a difference. In order to investigate this further I would need to know your exact product version. A small working sample illustrating the matter would be greatly appreciated and would help isolate the matter.
Reply Children
No Data
