I have a web data grid and on row selection, I need to pass the row's datakey value to a objectdatasource.
I have found where I can achieve this on the client-side with java-script but not on the server-side. I am assuming I should using the OnRowSelectionChanged ?
Thank you AgentD5. That's what I was missing. Here is the code I needed in case it helps anyone else:
Hi charlieamy,
You can set the autopostback flag on selection to true for RowSelectionChanged and then handle the RowSelectionChanged server event.
regards,David Young
