Visual studio help in general has gone downhill in quality since the 90's in my opinion. Then, it just worked. Now, it is constantly buggy.
None of the 11.2 asp.net help works. All pages have a error with onLoad javascript not found. I have repaired the install, didn't help.
The install I used was:
NetAdvantage_ASPNET_20112_VS2010Help.msi
I have tried the MS Help Viewer 1.1 and H3Viewer, same issue.
Hello cyberplasm ,
Thank you for contacting Infragistics developer support.
Generally when you run the local documentation from StartMenu ->All programs ->Infragistics -> NetAdavantage 2011.2 ->ASP.Net -> Documentation -> Documentation(Local). The documentation should open in Microsoft Document Explorer. This should be installed when you’ve installed your VS. The version of Microsoft Document Explorer I’m currently using is 9.0.
You should be able to open the documentation without any issues with it.
You can also view the documentation online at:
http://help.infragistics.com/NetAdvantage/ASPNET/2011.2/CLR4.0/
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
