we load a lot of infragistics controls in a web page and we see it spends a lot of time executing the ig_dispose function when we unload that page.
When the number of controls is very high, we get the following message: "Stop running this script? A Script on this page is causing Internet Explorer to run slowly. If it continues to run, your computer may become unresponsive. Yes / No"
Is it necessary to call this function so many times (recursively)? Is it necessary to call this function at all? Why is it only executing when the browser is IE and the number version is less than 9? What happens in the other browsers?
Thanks in advance!
Hello alfmag,
Every browser is different. For IE, we use ig_dispose() for garbage collection.
I noticed that you are using .NetAdvantage 4 Vol. 3. I recommend upgrading to at the earliest .NetAdvantage 10.3.
Below is a list of our supported environments:
http://ko.infragistics.com/support/supported-environments.aspx#SupportedEnvironments
If you have any questions, please let me know as well.
Thank you for the information. I have forwarded them to our Development team. I will be updating you as soon as I hear from them or by next week.
Hello Vivian,
I send you an image where you can see how many times ig_dispose is called (181.806)!
As you can see we are using version 4.3 (4.3.20043.1094).
Most of the controls used are Infragistics.WebUI.WebDataInput.WebTextEdit. We have also some Infragistics.WebUI.WebDataInput.WebDateTimeEdit and Infragistics.WebUI.WebDataInput.NumericEdit controls.
You didn´t answered my last question. Why do you only need to free up resources in IE?
Thanks.
I apologize for the delay in my response. I was trying to reproduce the issue you are having.
Yes. It is necessary to run ig_dispose(). This way we are able to free up resources used by our controls.
On the surface compatibility comes into mind. Please let me know what .NetAdvantage version and build you are using.
Furthermore, it will assist us in isolating the cause of the issue, if we have an idea of which of our control you have in your application.
