1070
Sorting is not working in ultrawebgrid
Sorting is not working after grouping. If i donot use groupby column sorting works fine.
i have set   AllowSortingDefault="Yes" in design page
In Code file
  'Grouping Code
       DgridQty.DisplayLayout.ExpandableDefault = Infragistics.WebUI.UltraWebGrid.Expandable.Yes
        DgridQty.DisplayLayout.ViewType = Infragistics.WebUI.UltraWebGrid.ViewType.OutlookGroupBy
        DgridQty.DisplayLayout.Bands(0).Columns(1).IsGroupByColumn = True
'Sorting Code
        DgridQty.Columns(5).SortIndicator = Infragistics.WebUI.UltraWebGrid.SortIndicator.Ascending
        DgridQty.Bands(0).SortedColumns.Add(DgridQty.Columns(5))
  • 8160
    Hello Dayana,
    could you try to use Add(UltraGridColumn,Boolean) Method. The true paramter should force the grid to be sorted in pre-render.
    DgridQty.Bands(0).SortedColumns.Add(DgridQty.Columns(5), True)
    Let  me know if this helps
    Thank you
