1840
Add additional Groups and Items
i use NetAdvantage 10.2.x with Net4.0. I use the WebExplorerBar with a Databinding to a WebHierarchicalDataSource (with a SqlDataSource as Base). I catch the 'itemselected' Event and in the JavaScript i check if it is a child-node and call some different JS-function (i use target-prop of the item to init the code for each item from the database and with eval(target); the fuction is called). This works great for the pattern meneu-item call js-function.
But now i need some menue-items with checkbox behavior or a textbox with a search-button. This should be possible with templates, right?
But how can i add a new group with checkbox-items and a new group with a textbox and a button to the WebExplorerBar??
Patric
  • 8160
    Hello Patric,
    Add new template, then create new group in the code, set the TemplateId to it and add this group to the Groups collection:
    <ig:WebExplorerBar ID="WebExplorerBar1" runat="server" Width="250px" DataSourceID="WebHierarchicalDataSource1"
            GroupContentsHeight="" OnPreRender="WebExplorerBar1_PreRender">
            <ClientEvents ItemSelected="WebExplorerBar1_ItemSelected" />
            <Groups>
                <ig:ExplorerBarGroup GroupContentsHeight="" TemplateId="Template1" Text="GroupA">
                </ig:ExplorerBarGroup>
            </Groups>
            <DataBindings>
                <ig:ExplorerBarItemBinding DataMember="AccessDataSource1_DefaultView" TextField="CategoryName"
                    ValueField="CategoryID" />
                <ig:ExplorerBarItemBinding DataMember="AccessDataSource2_DefaultView" TextField="ProductName"
                    ValueField="ProductID" />
            </DataBindings>
            <Templates>
                <ig:ItemTemplate ID="WebExplorerBar1Template1" runat="server" TemplateID="Template1">
                    <Template>
                        Search:<asp:TextBox ID="TextBox1" runat="server"></asp:TextBox>
                    </Template>
                </ig:ItemTemplate>
            </Templates>
        </ig:WebExplorerBar>
        protected void WebExplorerBar1_PreRender(object sender, EventArgs e)
            // Group 1
            ExplorerBarGroup group = new ExplorerBarGroup();
            //group.Text = "Folders";
            group.TemplateId = "Template1";
            this.WebExplorerBar1.Groups.Add(group);
            ExplorerBarItem item = new ExplorerBarItem();
            //item.Text = "Documents";
            item.TemplateId = "Template1";
            group.Items.Add(item);
