415
Data Disappears from node template after post back when clicking image buttons in node..
I have a WebDataTree with two templates.  I bind the data on the initial page load.
This works fine.  My templates contain image buttons.  If I click an image button, the data-derived portions of the template disappear.  Loading the data during each postback causes other problems.
Is there anyway for this data to persist between postbacks?
Here is my html code:
            <asp:Label runat="server" ID="lblCommandName" />
            <asp:Label runat="server" ID="lblCommandArgument" />
            <ig:WebDataTree ID="wdtCurricula" runat="server" DataMember="CATEGORIES" DataLoadingMessage="Please Wait"
                DragDropSettings-AllowDrop="true" DragDropSettings-DragDropMode="Move" OnNodeBound="wdtCurricula_NodeBound"
                OnItemCommand="wdtCurricula_ItemCommand">
                <DragDropSettings AllowDrop="True" DragDropMode="Move">
                </DragDropSettings>
                <DataBindings>
                    <ig:DataTreeNodeBinding DataMember="CATEGORIES" TextField="Category" />
                    <ig:DataTreeNodeBinding DataMember="REPORTS_LIST" TextField="Display_Name" />
                </DataBindings>
                <Templates>
                    <ig:ItemTemplate ID="Template1" runat="server" TemplateID="Template1">
                        <Template>
                            <asp:ImageButton ID="ibAddLevel0" runat="server" AlternateText="Add" ToolTip="Add"
                                CausesValidation="false" CommandArgument="argLevel0" CommandName="AddLevel0"
                                ImageUrl="~/Images/icons/add_16.png" />
                            <asp:ImageButton ID="ibEdit" runat="server" AlternateText="Edit Student Score" ToolTip="Edit Student Score"
                                CausesValidation="false" CommandArgument="something" CommandName="Edit" ImageUrl="~/Images/icons/edit_enabled16x16.png" />
                            <asp:ImageButton ID="ibRemove" runat="server" AlternateText="Remove Student" ToolTip="Remove student from class."
                                CausesValidation="false" CommandArgument="something" CommandName="RemoveStudent"
                                ImageUrl="~/Images/icons/delete_enabled16x16.png" />
                            <asp:Label runat="server" ID="lblCategory" Text='<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "Category")%>' />
                        </Template>
                    </ig:ItemTemplate>
                    <ig:ItemTemplate ID="Template2" runat="server" TemplateID="Template2">
                        <Template>
                            <asp:ImageButton ID="ibAddLevel1" runat="server" AlternateText="Add" ToolTip="Add"
                                CausesValidation="false" CommandArgument="argLevel1" CommandName="AddLevel1"
                                ImageUrl="~/Images/icons/delete_enabled16x16.png" /><%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "Display_Name") %>
                        </Template>
                    </ig:ItemTemplate>
                </Templates>
            </ig:WebDataTree>
Here is the relevant C# code:
        protected void Page_Load(object sender, EventArgs e)
            if (!IsPostBack)
                BindTree();
                BindGrid();
        private void BindTree()
            wdtCurricula.DataSource = GetReportsDS();
            wdtCurricula.DataBind();
        protected void wdtCurricula_NodeBound(object sender, DataTreeNodeEventArgs e)
            DataTreeNode thisNode = e.Node;
            if (thisNode.Level == 0)
                thisNode.TemplateId = Template1.TemplateID;
            else
                thisNode.TemplateId = Template2.TemplateID;
        protected void wdtCurricula_ItemCommand(object sender, DataTreeCommandEventArgs e)
            lblCommandName.Text = e.CommandName;
            lblCommandArgument.Text = e.CommandArgument.ToString();
Thanks!
