Hi
I'm using WebDataGrig from Infragistics Infragistics2.Web.v11.2.
WebDataGrid has enable pagination mode "NextPreviousFirstLast".
WebDataGrid has a checkbox column.
<ig:BoundCheckBoxField DataFieldName="CONECTION" Key="CONECTION"> <Header Text="CONECTION" /> <Footer Text="CONECTION" /></ig:BoundCheckBoxField>
On the page first load the "checkbox" are rendered correctly, but after the pagination the "checkbox" appear incorrectly, as image below:
More problem information:
On the first page load, the src image is as follow:
"http://localhost/WebAppTest/ig_res/Default/images/ig_checkbox_on.gif"
After pagination, the src image is as follow:
"http://localhost/ig_res/Default/images/ig_checkbox_on.gif"
The webconfig is as follow:
<infragistics.web styleSetName="Default" styleSetPath="~/ig_res" imageDirectory="~/ig_res/Default/images" />
