I want to debug your samples.
On compilation I get the the error:
Error 1 The type 'Infragistics.Web.UI.NavigationControls.WebDataMenu' exists in both 'c:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\samplesbrowser\26ff691f\b3bffaa8\assembly\dl3\6976fd6a\00c58c68_329acc01\Infragistics.Web.DLL' and 'c:\WINDOWS\Microsoft.NET\assembly\GAC_MSIL\Infragistics4.Web.v11.2\v4.0_11.2.20112.1019__7dd5c3163f2cd0cb\Infragistics4.Web.v11.2.dll' C:\Documents and Settings\ZG6\Desktop\Samples\Infragistics.Web.AspNET\App_Code\CS\CLR2\WebDataMenu\WebMenuDataCommand.cs 16 31 C:\...\Infragistics.Web.AspNET
O.K.
After reinstalling the sample, it works.
I installed a file name NetAdvantage_ASPNET_20112_Samples.msi
I add anything to the samples, but the references point to the Bin folder
Hello drpoalim,
Can you tell me which exact samples do you attempt to debug, what install package do you use and with what version?
Also do you added the assemblies to the project Bin folder or you reference them only through GAC?
You can also review the following links:
http://stackoverflow.com/questions/371426/asp-net-error-the-type-foo-exists-in-both-temp1-dll-and-temp2-dll
http://stackoverflow.com/questions/5425638/asp-net-error-the-type-exists-in-both-directories
http://forums.asp.net/t/1093116.aspx/1
