I use WebDataTree and I am doing manual load on demand by populating the nodes on NodePopulate event.
I have seen that the event will be fired only once per node.
For example, if I load 3 levels of tree data initially and expand them all, when I expand a node in the third level, the NodePopulate event is fired for it. After this, if I collapse the root level node and expand it again, it fires NodePopulate event even for root level node. Hence I manually load the root's children and similarly it's children. Now in the third level, if I again try to expand the same node which I did earlier, NodePopulate event is not fired for it.
Can anyone tell me if I need to do anything in specific to fix this.
Here is my Tree definition:
<ig:WebDataTree ID="Tree" runat="server" InitialExpandDepth="0" EnableExpandOnClick="false" StyleSetName="Office2010Blue"
InitialDataBindDepth="0" EnableAjax="true" EnableConnectorLines="false" Font-Size="Small" OnNodeDropped="serverNodeDropped">
<AutoPostBackFlags NodeDropped="On" />
<ClientEvents NodeClick="Tree_NodeClick" />
</ig:WebDataTree>
Code behind:
protected void treeNodePopulate(object sender, DataTreeNodeEventArgs e)
this.Tree.DataBind();
if (!e.Node.HasChildren)
//Logic to load list of employees under e.Node
foreach (Employee emp in childNodes)
DataTreeNode treeNode = new DataTreeNode();
treeNode.Text = emp.NodeDescription;
treeNode.Key = emp.NodeID;
treeNode.NavigateUrl = emp.NodeURL;
treeNode.ImageToolTip = emp.LevelDepth.ToString();
treeNode.IsEmptyParent = true;
treeNode.ImageUrl = emp.ImageURL;
treeNode.Value = emp.NodeVal;
e.Node.Nodes.Add(treeNode);
protected override void OnInit(EventArgs e)
base.OnInit(e);
this.Tree.NodeBound += new DataTreeNodeEventHandler(treeNodeBound);
this.Tree.NodePopulate += new DataTreeNodeEventHandler(treeNodePopulate);
protected void Page_Load(object sender, EventArgs e)
if (!Page.IsPostBack)
// Logic to load the Employee data corresponding to first 3 levels and populate the tree
Hi nancy1985,
Please feel free to contact me if you have any questions regarding this matter.
From what I can understand, when binding your tree initially, you are setting the isEmptyParent property for its leaf nodes. At a later point the isEmptyParent is also set for the root node, resulting in repopulating the tree. I suggest that you ensurte that the IsEmptyParent property is again set for the leaf nodes at that stage as they are essentially being recreated. It would be helpful to know a bit more regarding how your tree is bound (and when the child nodes' properties are set).
Hope this helps.
