I'm new to Infragistics and i want to use the WebDataTree. I can build the tree and i want to show an icon near each node. This works via NodeSettings. But i want to show a different icon if the node is expanded or collapsed. Like showing an Folder-icon when the node is collapsed and an OpenFolder-icon if it is expanded.
What must i do to achieve that?
Martin
Hi Petar,
i want to reduce Postbacks in my app and want to know if there is an alternative to change the icon, e.g. via CSS and/or JavaScript.
Hi Martin,
Glad to help. Please feel free to contact me should any additional questions arise.
Dear Petar,
thanks for your help. Your suggested solution works fine.
In this scenario I can suggest that you enable postback on NodeExpanded and NodeCollapsed. By handling the respective server-side events you can set the ImageUrl or the target node as needed. For instance:
protected void WebDataTree1_NodeExpanded(object sender, Infragistics.Web.UI.NavigationControls.DataTreeNodeEventArgs e) { e.Node.ImageUrl = "~/add_disabled.gif"; }
Please let me know if this helps.
