We are using wbdropdown to show a list of NDC medications. The user will select one and only one medication from the list. We are interested in the user having type-ahead functionality.
The master list is >24000 items which presents performance problems loading the page. can we delay binding of the webdropdown until the user has typed in 3 characters, and then use those 3 characters as a filter in the underlying query? How?
Thanks!
Hi johnvrsm,
Thank you for your reply.
I suggest that you enable load on demand for your WebDropDown in order to increase performance. A detailed guide on how this can be achieved is available at:
http://help.infragistics.com/NetAdvantage/ASPNET/2011.2/CLR4.0/?page=WebDropDown_Load_on_demand.html
Hope this helps.
Thanks. I've added this, but the control is still databinding on page load which takes a very long time as it is loading all 24000+ items in the datasource. How do I stop this?
See my code below:
<ig:WebDropDown ID="wddMedications" runat="server"
Width="200px"
DropDownContainerWidth="300px"
DropDownContainerHeight="500px"
DataSourceID="sdsMedications"
TextField="medication_dispensed"
ValueField="generic_product_id"
EnableAnimations="false"
Height="18px"
Button-ImageUrl="~/ig_res/Default/images/windows_DropDownButton.png"
Button-HoverImageUrl="~/ig_res/Default/images/windows_DropDownButton.png"
Button-PressedImageUrl="~/ig_res/Default/images/windows_DropDownButton.png"
CurrentValue="-- Select --"
AutoPostBackFlags-ValueChanged="On"
OnSelectionChanged="wddMedications_SelectionChanged"
ClientEvents-ValueChanged="wwdMedications_ValueChanged"
EnableAutoFiltering="Server"
ClientEvents-AutoFilterStarting="wddMedications_AutoFilterStarting"
TabIndex="1">
function
wddMedications_AutoFilterStarting(sender, e) {
(eventArgs.get_value().length < 3) {
eventArgs.set_cancel(
Hi johnnvrsm,
You requirement may be achieved by handling the AutoFilterStarting clientside event which may be cancelled if the current value of the control is shorter than n characters. For instance:
Please note that you may also control the rate with which the items are filtered by modifying the AutoFilterTimeoutMs in order to defined the interval before a filtering request is sent to the server:
http://help.infragistics.com/NetAdvantage/ASPNET/2011.2/CLR4.0/?page=Infragistics4.Web.v11.2~Infragistics.Web.UI.ListControls.WebDropDown~AutoFilterTimeoutMs.html
