Hello .
Using Infragistics 2011 Vol.2
I am switching from the classic igtab:UltraWebTab control to the new ig:WebTab control
Please allow me a newbie question: where is the TabSeparator ?
I want to migrate exactly the current appearance , screen capture is attached.
I am reading the local help installed on my computer and the discussions here too,but any help is appreciated.
Thank you
P.S. Meanwhile I have found the answer myself by looking around this forum
The C# MarginTrailing Property get/sets margin between this tab item and next.
That defines space/separator between tab items.
Can this property be set in .css ?
Hi Renuk,
If you ask about properties available for UltraWebTab, then custom image for tab-separator can be set by exactly same property as image for tab-item: DefaultImage. Since tab-separator does not support states (hover/selected/disabled), state-images are not available for separator. In order to customize properties of tabs and tab separators, I suggest you to use visual-designer-dialog for Tabs property of UltraWebTab.Below is example to set image for separator:<igtab:UltraWebTab ID="UltraWebTab1" runat="server"> <Tabs> <igtab:Tab Text="New Tab"></igtab:Tab> <igtab:TabSeparator DefaultImage="./images/arrow.gif"></igtab:TabSeparator> <igtab:Tab Text="New Tab"></igtab:Tab> </Tabs></igtab:UltraWebTab>
Hi, Renuk.
I don't think WebTab have such a functionality. But I think you can use some of the "TabCssClasses" of the "ContentTabItem" and achieve similar effect. You can see the list of properties that are available.
I will wait for your feedback.
Best regards, Nikolay Alipiev
How do i get a TabSeparator image in a WebTab?
<Tabs>
<igtab:TabSeparatorTag="preset">
<StyleWidth="20px"></Style>
Hi Shehla,
The tab-item has property ToolTip which is applied to tab-label.
<ig:WebTab ID="WebTab1" runat="server" ...> <Tabs> <ig:ContentTabItem runat="server" Text="Tab 1" ToolTip="This is tab1"> ... </ig:ContentTabItem> ... </Tabs> </ig:WebTab>
Hi
How can I get tooltip to work for each tab?
I want screen reader to say which tab they are on. Hitting enter does display its content but I want to give audio instruction on each tab selected.
Please help.
shehla
