Folks,
I am using ig:WebDropDown with IG theme. but for some reason dropdown list items are displaying transparent background and not formatted.
any ideas?
Hi Bebu,
Were you able to see the sample attached to my previous response.
If this does not help. Please attach your sample. I will review it as soon as possible and advice you further.
Sincerely,
Georgi Sashev
Developer Support Engineer
Infragistics, Inc.
Hello Bebu,
Sorry for the delayed response.
I tested the WebDropDown in User Control with v11.2.2055 and the markup you provided but I could not reproduce the issue. If you still need assistance with the matter I would need you to provide a small sample, replicating this behavior.
I am having the same issue. The drop down list container is not solid so the list text is overlaying the other controls.
The webdropdown is being used in a roweditingtemplate of a webdatagrid that is located on a USER CONTROL.
I have verified that the css and images are located in the ig_res folder
