3760
WHDG - GridControls.ContainerGrid.OnPreRender databind problem
Hi all,
I have a custom user control used to handle the paging of the whdg.
During a change in the custom pager a post back is initiated.
According to the stack trace (which is included in the attached sample) 'Object reference not set' error is thrown during the GridControls.ContainerGrid.DataBind().
I have not been able to track the reason for this as the grid's datasource is set on every post back.
It seems that after the OnPreRender of the page, the controls fire a OnPreRender event and during this process it seems that this are going wrong.
I have attached a sample reproducing the issue.
Steps to reproduce:
1. Run application
2. In the GridPager  "Views" dropdownlist, select Red Records.
My environment is as follows:
 VS2010
IE9
Widows 7 32 bit.
Infragistics ASP.Net Version 11.2.20112.2086
.Net 4
The grid is located inside a WebTab.
Grid_PreRender_Databind Issue.zip
  • 8160
    Hello JJB,
    I have created new support ticket CAS-90743-RFP1XR. You will be notified automatically when bug: 110950 is fixed.
  • 33839
    Hi JJB,
    I took a look at your sample and was able to replicate the problem.  I have submitted this bug internally as # 110950.  If you contact Developer Support, they can attach your case to the bug so you can be alerted when the fix is completed.
    regards,
    David Young
