615
False Client-side selectionchanged firing
I have found that if a user types the Home or End keys in the "text box" portion of the WebDropDown control (in order to see text that is hidden, for instance) this triggers the SelectionChanged Client event, but the selection has not changed, and the corresponding server event is not fired.  I worked around this by having the event check for these keys, as in the following code:
function EmployeeNameWebDropDown_SelectionChanged(sender, eventArgs)
///<summary>
///</summary>
///<param name="sender" type="Infragistics.Web.UI.WebDropDown"></param>
///<param name="eventArgs" type="Infragistics.Web.UI.DropDownSelectionEventArgs"></param>
    var event = eventArgs.get_browserEvent();
    var keyCode = event.keyCode;
    if (keyCode == 35 || keyCode == 36)
        alert('I am under no illusions that the selection was changed.');
    else
        alert('I think the selection was changed!');
Does anyone know if this will be fixed, or are there other key codes I should watch for, or am I missing something?
Thank you,
Ross
Parents Reply Children
No Data
