Intellisense is not working. the "id:" has the squiggly line under it and the error message: "Unrecognized tag prefix or device filter".
Had the same problem under 11.2, and it was a recognized bug that was supposed to be fixed.
Any idea of the resolution??
Chuck,
I hope that Microsoft will fix this soon. Infragistics will support VS 2011 once after it is released.
Thanks for the reminder that everything needs to be registered to work. But in this case, using VS 11 Beta causes the problem. Using VS 2010, intellisence works just fine. Only in the Beta version I don't get the intellisence.
I was contacted by another help person, and this is a known problem and they are trying to get MS to help with a fix.
thanks Chuck
Hello csnyder_ptb,
make sure that all needed assemblies are registered correctly on the page and in web.config file
Hope this helps
