I have a WebDataMenu that is working quite nicely. My issue is that I don't want it to close if the user accidentally hovers off of the menuItems, but I do want it to close when they click on a menuItem. I have the command for cancelling the collapse:
eventArgs.set_cancel(true)
but, I'm having trouble figuring out the correct way to mimic what I want. The issue is that my WDM is several levels deep, and it is quite easy to accidentally move the cursor off of the items... causing the entire menu to collapse (which is a pain for the user). Aside from preventing this behavior, I want the control to behave as normal. I've gotten pretty close by allowing or cancelling the close based on Unhovered/Hovered/Selected events, but I keep getting instances where part of the menu a few levels deeper than where I left the menu try to stay open (with their parents). Another perfectly acceptable solution would be to have enough of a delay before the menu closes that the user could catch get back on the menu and continue on.
So, to spell out my questions...
1. Is there a way to close the menuItems that are children of a particular item?
2. Is there a way to delay the close of menuItems so the user can get back on the menu without having to drill all the way back down to where they were?
Any other valid solutions to my issue are more than welcome.
For those looking to solve this same issue, I've decided to just take the best solution I've come across and move on. I ended up just setting the SubMenuClosingDelay to 500 mlliseconds (designer property). This allows the user enough time to get back on the menu before the menu rolls back up. Not EXACTLY what I was hoping to accomplish, but a decent compromise.
Anybody?
