480
Repeating records on export
HI,  using V10.3 webexcelexporter it is exporting the first 13 records severaltimes before exporting the rest. Below is my code. what am I doing wrong?
<ig:WebExcelExporter ID="WebExcelExporter1" runat="server" DataExportMode="AllDataInDataSource" ExportMode="Download" EnableStylesExport="false" OnCellExporting="WebExcelExporter1_CellExporting" > </ig:WebExcelExporter>
 Protected Sub WebExcelExporter1_CellExporting(ByVal sender As Object, ByVal e As Infragistics.Web.UI.GridControls.ExcelCellExportingEventArgs) Handles WebExcelExporter1.CellExporting
        If (e.CurrentColumnIndex.Equals(8) And (Not e.IsHeaderCell) And (Not e.IsSummaryCell) And (Not e.IsFooterCell)) Then
            e.Cancel = True
            If IsDBNull(Me.WebDataGrid1.Rows(e.CurrentRowIndex - 1).Items.GetValue(18)) Or Me.WebDataGrid1.Rows(e.CurrentRowIndex - 1).Items.GetValue(18) = 0 Then
                e.WorksheetCell.Value = "Select Value"
            ElseIf Me.WebDataGrid1.Rows(e.CurrentRowIndex - 1).Items.GetValue(18) = 1 Then
                e.WorksheetCell.Value = "Retain"
            ElseIf Me.WebDataGrid1.Rows(e.CurrentRowIndex - 1).Items.GetValue(18) = 2 Then
                e.WorksheetCell.Value = "Remove"
            End If
        End If
        If (e.CurrentColumnIndex.Equals(9) And (Not e.IsHeaderCell) And (Not e.IsSummaryCell) And (Not e.IsFooterCell)) Then
            e.Cancel = True
            e.WorksheetCell.Value = Me.WebDataGrid1.Rows(e.CurrentRowIndex - 1).Items.GetValue(17)
        End If
    End Sub
  • 33839
    HI conrad1209,
    If you don't handle that event, do you still get repeating rows?  Do you have a full sample you could attach?  Maybe it's the data and the event that do it.
    regards,
    David Young
