90
java script error while adding a row into web data grid from the client side
I am using infragistics drag and drop framework. I am dropping a node from the tree and adding it to webdatagrid. In the drop handler, i am adding a row to the grid on the client side. The grid has 2 bound data fields and one template datafield which is a webdropdown. I am getting the following error while adding
Microsoft JScript runtime error: Sys.ArgumentUndefinedException: Value cannot be undefined.
Parameter name: type
If I reload the page and drag and drop this error is not seen or If I remove the templatedatafield from the webdatagrid the error is not seen
I am adding to the grid like below
 var newDisplayColumn = [sourceContent, key, 'SUM'];
 var grid = $find("<%= DisplayColumnGrid.ClientID %>");
                var rows = grid.get_rows();
                rows.add(newDisplayColumn);
It is firing the insert method of the grid.  What values need to be supplied in the array. Do we need to do any thing extra for template data field.
How can I debug this issue.
Please provide me guidance on this
