945
WebExcelExporter not working with WHDG.....
I have a WHDG that I'm trying to export via the WebExcelExporter. Below is my code. In Internet Explorer, when i click the button to download to excel, I see that the postback is firing the code but, the file that its trying to give me back is "default.aspx" and not the XLS file. When i try it on FireFox, I get the .XSL file to return but in opening the document, i see an empty grid. How do I send the WHDG as is (with out having to refresh the datasource) on the page to the explorter?
Below is my code.
/*********************** ASPX *************************/
<form id="form1" runat="server">
        <ig:WebScriptManager ID="WebScriptManager1" runat="server" />
        <div>
            <table>
                <tr>
                    <td>
                        <igmisc:WebGroupBox ID="WebGroupBox1" runat="server" Width="295px">
                            <Template>
                                <table>
                                    <tr>
                                        <td style="width:85px;">Start Date : </td>
                                        <td style="width:140px;"><ig:WebDatePicker ID="WebStartDate" runat="server" /></td>
                                        <td style="width:60px"><igtxt:WebImageButton ID="WebImageButton1" runat="server" OnClick="Search" Text="Search"/></td>
                                    </tr>
                                    <tr>
                                        <td style="width:85px">End Date : </td>
                                        <td style="width:140px;"><ig:WebDatePicker ID="WebEndDate" runat="server" /></td>
                                        <td style="width:60px"><asp:Button runat="server" ID="btnExport" OnClick="btnExport_Click" /></td>
                                    </tr>
                                </table>
                            </Template>
                        </igmisc:WebGroupBox>
                    </td>
                </tr>
                <tr>
                    <td>
                        <asp:UpdatePanel ID="UpdatePanel1" runat="server" UpdateMode="Always">
                            <Triggers>
                                <asp:AsyncPostBackTrigger ControlID="WebGroupBox1$WebImageButton1" EventName="Click"/>
                            </Triggers>
                            <ContentTemplate>
                                <ig:WebHierarchicalDataGrid ID="WHDG" runat="server" Height="800px" Width="1000px" InitialDataBindDepth="-1" EnableAjax="False" />
                            </ContentTemplate>
                        </asp:UpdatePanel>
                    </td>
                </tr>
            </table>
        </div>
        <ig:WebExcelExporter ID="WebExcelExporter1" runat="server" />
    </form>
/*********************** CS *************************/
public partial class ACDVolume : System.Web.UI.Page
        protected void Page_Load(object sender, EventArgs e)
            if (!Page.IsPostBack)
                using (XmlDataSource xmlDataSource = new XmlDataSource())
                    xmlDataSource.XPath = @"/CallCenters/CallCenter";
                    xmlDataSource.EnableCaching = false;
                    xmlDataSource.Data = GetCMS(WebStartDate.Text, WebEndDate.Text);
                    WHDG.DataSource = xmlDataSource;
                    WHDG.DataBind();
        public void btnExport_Click(object sender, EventArgs e)
            this.WebExcelExporter1.WorkbookFormat = Infragistics.Documents.Excel.WorkbookFormat.Excel97To2003;
            this.WebExcelExporter1.Export(this.WHDG);
        public void Search(Object sender, EventArgs e)
                WHDG.GridView.ClearDataSource();
                WHDG.DataBind();
        private string GetCMS(string WebStartDate, string WebEndDate)
            string strSQL = "dbo.dashboard_callcenter_metrix4";
            string result = "";
            using (SqlConnection connection = new SqlConnection("Server = 10.50.8.80;User ID = jpmc;Password = cstsqa;DATABASE = cstsdb"))
                using (SqlCommand command = new SqlCommand(strSQL, connection))
                    command.CommandTimeout = 0;
                    command.CommandType = CommandType.StoredProcedure;
                    command.Parameters.AddWithValue("@startDate", WebStartDate);
                    command.Parameters.AddWithValue("@endDate", WebEndDate);
                    using (DataTable dataTable = new DataTable())
                        using (SqlDataAdapter dataAdapter = new SqlDataAdapter(command))
                            dataAdapter.Fill(dataTable);
                        if (dataTable.Rows.Count > 0)
                            DataRow dataRow;
                            for (int i = 0; i < dataTable.Rows.Count; i++)
                                dataRow = dataTable.Rows[i];
                                result += dataRow[0].ToString();
            return result;
