580
RowSelectionChanged Server Side event not firing
Hi team,
                 I am using a webdatagrid in my application.In it i have set the selection to Row.  Now i want to do some task in my code behind when the user selects some row in my grid.I tried to use the Selection.RowSelectionChanged event for that, but it doesnt trigger when i select any row. Am i doing something wrong here? How do i achieve this ?
I was able to trigger the client side event when row selection changed but my functionality is such that i want to handle the event in code behing. Please advice. Thanks
  • 33839
    Suggested Answer
    Hi yadusaxena,
    Did you set the autopostback flag to true for RowSelectionChanged on the AutoPostbackFlags object off of selection.  If it is false, then the server event fires at the next postback and not immediately.  Be warned, that if you have it true, and ajax is on, updating other controls will not work since only the grid is refreshed.  You'd need to turn ajax off for that case.
    regards,
    David Young
