180
Header Text as Caption from DataTable
I am using WHDG 12.1, and I am using a HierarchicalDataSource which is binded to a objectdatasource (DataSet). The data all loads fine, but I want to change the headers of the columns.
They are currently use the column name, but I want it to use the caption from the datacolumn within the dataset.
I know this would be easy to do in markup but I have no idea what information the user would be requesting, so is there anyway to find a column in codebehind and change the header.Text?
Another Problem: How would I hide a column in code based if DataColumn.ExtendedProperties.Count > 0? Again I don't know what column it would be, so I need it done in code
Any help would be great! Thanks
The aspx page mark up:
<ig:WebHierarchicalDataGrid ID="dataGrid2" runat="server"
        Height="600px" Width="100%" DataSourceID="WebHierarchicalDataSource1"
          ondatabound="dataGrid2_DataBound">
          <GroupingSettings EnableColumnGrouping="True" />
          <Behaviors>
            <ig:Sorting Enabled="true" />
            <ig:ColumnMoving Enabled="true" />
            <ig:ColumnResizing Enabled="true" />
            <ig:VirtualScrolling Enabled="true" ScrollingMode="Virtual" />
          </Behaviors>
        </ig:WebHierarchicalDataGrid>
    <ig:WebHierarchicalDataSource ID="WebHierarchicalDataSource1" runat="server">
        <dataviews>
            <ig:DataView ID="Data" DataMember="DefaultView"
                DataSourceID="ObjectDataSource1" />
        </dataviews>
    </ig:WebHierarchicalDataSource>
    <asp:ObjectDataSource ID="ObjectDataSource1" runat="server"
        OldValuesParameterFormatString="original_{0}"
        onobjectcreating="ObjectDataSource1_ObjectCreating"
        onselecting="ObjectDataSource1_Selecting" SelectMethod="getFilterData"
        TypeName="Convallis.CRM.Business.Filters.FilterHandler"
          onselected="ObjectDataSource1_Selected">
        <SelectParameters>
            <asp:ControlParameter Name="filterID" ControlID="queryList" PropertyName="SelectedValue" Type="Int32" />
            <asp:Parameter Name="clientID" Type="Int32" />
        </SelectParameters>
    </asp:ObjectDataSource>
