I am using Infragistics.WebUI.UltraWebToolbar.v4.3 in ASP.NET 2003 with framework 1.1.
This ultra web tool bar works in IE9 but doesn't work with the Mozilla Firefox.
Here is the exception i get when i load the ultra web tool bar
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.FormatException: Input string was not in a correct format. Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
[FormatException: Input string was not in a correct format.] System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) +10162435 System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) +207 System.Convert.ToInt32(String value) +46 Infragistics.WebUI.UltraWebToolbar.UltraWebToolbar.getRenderer() +352 Infragistics.WebUI.UltraWebToolbar.UltraWebToolbar.OnPreRender(EventArgs e) +163 System.Web.UI.Control.PreRenderRecursiveInternal() +108 System.Web.UI.Control.PreRenderRecursiveInternal() +224 System.Web.UI.Control.PreRenderRecursiveInternal() +224 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3394
Hello Arshi,
Please refer to our supported environments page:
http://ko.infragistics.com/support/supported-environments.aspx#SupportedEnvironments
FireFox versions newer than Firefox 7 are supported for IG versions 11.1 and later. The version you’re using is pretty old so I’d advise you to upgrade to a newer version if you need support for the newest browser versions.
Let me know if you have any further questions regarding this.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
