I have created a 3D Pie Chart using UltraChart controls but the Labels are overlapping if data increases. Is there a way, so that atleast labels should not overlap. If I adjust the xRotation and YRotation value then it fixes the problem but again after some days when data changes some other labels starts overlapping.
Sunil Kumar
Thanks, i need it
Is this a fixed problem?
I'm using Infragistics 2013.2 and my Pie Charts Labels are overlapping.
Roger
Hi Sunil IMM,
This is a known Issue and it logged in our system. We expect it to be fixed and will be included in future service release. I will open you a ticket in our system in order for you to follow the linked issue and to receive notifications when the issue state is changed. The ticket number is: CAS-92885-V7M5FC
Sincerely,
Georgi Sashev
Developer Support Engineer
Infragistics, Inc.
