I have a page with a websplitter on it.
In the left hand pane I have some text boxes and drop down lists.
In the right hand pane I have a drop down on top of a datagrid.
When I have compatibility mode turned off all of the objects display properly, but when it is turned on the dropdown containers are no longer on the bottom of the dropdown box. The pictures below is of the dropdowns in Compatibility View
This shows the filter control of the webgrid
On pages without the splitter all of these controls function normally. Can someone tell me a work around/fix?
Hello mts176,
In addition, I also suggest using the current Service Release.
If you have any questions, please let me know as well.
Thank you for the information.
At the moment I am not able to reproduce the issue. Please let me know if you have customized CSS classes.
I also attached the sample. Please let me know if the sample demonstrates the behavior you are seeing, or otherwise.
Please let me know what version of NetAdvantage you are using.
