I have a WebDataGrid and am able to add a row if I insert the data and tab off or hit the enter key, but I have a save button outside of the grid that the users are used to pressing after they have updated existing records and I want them to be able to press this button when they have inserted new data to add a new row. Any suggestions?
Hi, Angela.
I don't know if I will be able to help you. I suppose the posts you've already red, have more information about this problem. The WebDataGrid can disable editing on a column, but I suppose this is not appropriate for your case. As far as for the next 12.2 there is not going to have cell editing feature for sure, and I don't know about future releases. But I think you can do a feature request about this functionality and it is possible to be implemented in the future, if the architecture of the control allows this. If this is common problem, I suppose that there is already such requests, and if you want to understand some information and progress on this you can create forum thread and the guys from Developer Support will take care to give you most recent information.
Best regards, Nikolay
I know this is not the best place to ask this question, but you were so helpful with this problem...so I thought I would try here first.To my knowledge, there isn't an easy way to do the following while using the WebDataGrid: (This is how I set a cell to allow/not allow editing on a specific cell using the UltraWebGrid) Protected Sub grid_InitializeRow(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.RowEventArgs) Handles grid.InitializeRow If Page.User.IsInRole("App_AIM_Admin_Users") Then e.Row.Cells.FromKey("DOS").AllowEditing = Infragistics.WebUI.UltraWebGrid.AllowEditing.Yes Else If e.Row.Cells.FromKey("Approved_Flag").Value = 1 Then 'checked e.Row.Cells.FromKey("DOS").AllowEditing = Infragistics.WebUI.UltraWebGrid.AllowEditing.No Else e.Row.Cells.FromKey("DOS").AllowEditing = Infragistics.WebUI.UltraWebGrid.AllowEditing.Yes End If End If End Sub
I have a workaround, but it seems confusing and I don't really want to go through the trouble of changing all of the pages in my application if this is a feature that will be added in the next WebDataGrid release. For the most part, I have been able to replicate how things worked with the UltraWebGrid in the WebDataGrid...but this is the one thing that I definately see as a big disappointment for the WebDataGrid. Do you know if there are plans to have this feature added to the WebDataGrid anytime soon? I have seen several posts where others have asked for it and have been surprised that it's not a current feature.If there is somewhere else I should post this question that would be more appropriate, please let me know and I will be happy to do so.
I was not able to get it to work for some reason. As a quick fix, I just added an "Add Record" button and kept the "Save" button, but renamed it "Save Changes". I used the code from one of your previous post to get it to work the way I wanted it to work. I got pulled off on another project, so I wasn't able to spend more time trying to determine why I wasn't able to get it to work. I will definately have to revisit this one to see if I can get it to work at some point.Thank you very much for all of your time and help. I really appreciate it.
Hi, Algunderson.
Did my last post helped you to resolve your issue?
Best reagards, Nikolay
This problem has nothing common with editing. It' because every time you press the "Save" button, the Add Row is sent to the server, even if it's empty. It's because get_rowAdding() gets reference to the object that represents the new row template at the bottom of the grid and every time the row is added, even it is with no data. That's why you first need to check if there is a new cell values in the Add Row.
In most of the cases it's not recommended to use internal methods, like _commit(), because as you see it's possible that some problems may occur. But don't worry I've created a script that checks if the row is been updated and if yes, then it is added as a new row, when the "Save" button is pressed.
The following code defines an array of the default cell values for every column and just checks if the new cell value is different from the default one. Unfortunately I couldn't find grid method that do this, that's why I've created the code below that works for me. I hope it will resolve your issue.
var toSave = false;
function cancelRowAdding(sender, e) {
if (!toSave) {
e.set_cancel(true);
toSave = false;
function saveRow() {
var rowToAdd = $find("<%= wdg1.ClientID %>")
.get_behaviors().get_editingCore()
.get_behaviors().get_rowAdding();
toSave = true;
if (isRowToAddChanged(rowToAdd)) {
rowToAdd._commitRow();
function isRowToAddChanged(rowToAdd) {
var cellCount = rowToAdd.get_row().get_cellCount(),
cellInd = 0,
// you don't need that array if all your default cell values are null.
defaultRowValues = ["---", null, null, null, null, null, null];
for (cellInd; cellInd < cellCount; cellInd++) {
if (rowToAdd.get_row().get_cell(cellInd).get_value() !== defaultRowValues[cellInd]) {
return true;
// If all your default values are null then use the following code:
if (rowToAdd.get_row().get_cell(cellInd).get_value() !== null) {
</script>
