Looking at the documentation, there is no clear way that I see to delete/remove a tab. There are addTab, addCopy, moveTab, etc... but no deleteTab or removeTab or even closeTab.
I need to completely delete a tab. Has anyone seen a way to do this client-side?
Ok I got it working with the latest Service Release of Infragistics35.Web.v11.2 version Version=11.2.20112.2159,
and also Infragistics35.Web.v12.1 with latest service release Version=12.1.20121.2048.
Dk
Hi VK,
I was on vacation and could not reply you earlier. Actually I tried my sample application with Infragistics35.Web.v12.1, Version=12.1.20121.1005 and I am getting exactly same behaviour.
Appreciate your help!
Hi Dk,
I built debug dll for version 11.2.20112.1019 and reproduced exception, which you referred to.
Please, get latest service release for NetAdvantage.
We have license for Infragistic dll 11.2 dll and its version is 11.2.20112.1019.
About AjaxControlToolkit , I was using old version earlier and was facing similar issue. Upgrading to latest version did not help at all.
Thanks for prompt responses,
I cannot give my personal email, maybe there are some other options to down load large attachement. I can consult developer support about that.
I assume that you have latest version of 11.2 dll, which is 11.2.20112.2159 or 11.2.20112.2141. Those versions should be ok. If you have earlier version, then please give me its exact version. (You may look at File version within Details of dll Properties).I could try to find its date in tfs history, gets all files for that date and build debug dll from them. Though, I would like to avoid similar.That is possible that there are other changes in codes of WebTab (besides InstantiateTemplates within OnInit), which make difference for your application.
The best choice is to use the most recent available service release.
To exclude possible issue with version of AjaxControlToolkit, you may replace it in your sample by ScriptManager and check if it makes any difference.
