Hi
I used infragistics Version=11.1.20111.1006 in my web application and I have created a websetup . I have installed in my client machine . This create a virtual directory in my client machine IIS. When I access the link due to unavailability of an infragistics on my client machine its giving me an error . but it working correct on my machine because I have installed infragistics .
Please give me a solution for this , so that I can install an Application on various users machine
Hi Maya
The links which you provided is helpful and its working fine . Thanks for providng me a solution.
thanks. that worked. it was infragistics4 and infragistics35 mismatch.
Hello Bill,
Make sure that it’s the same service release version. For example if all your reference point to:Assembly="Infragistics4.Web.v12.1, Version=12.1.20121.1005….
Then make sure that the assemblies you reference are of the same version.If there is a mismatch for example if the dll version is: 12.1.20121.2020.Then you need to either change the references to point to that version or change the assemblies to match the version.
Let me know if you need further assistance.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
I have used Web Data Grid and Web Progress bar in one of my asp.net application. Now when i published the code and tried to load on client site it is not loading page.
I have added reference in web.config file and placed dlls in bin folder on production server. but it gives me error unable to load assembly 'Infragistics.Web.v12.1'
i believe i have followed the links above regarding deployment. i have version 12.1
thanks.
Bill
Hi Shamtesh,
We are still following this forum thread.Have you been able to take a look at the provided links, do you still need help?
If you have any other questions please do not hesitate to contact us.
