how to get the value of parent expanded.because by using that i have to set the textbox field to editable.suppose if the first parent is expanded then i have to make the textbox2 as editable else if the second parent is expanded then i have to set the textbox3 as editable.Here is the code am using
if (WebHierarchicalDataGrid2.GridView.Rows[0].HasRowIslands)
ContainerGrid childGrid = this.WebHierarchicalDataGrid2.GridView.Rows[0].RowIslands[0];
for (int i = 0; i < childGrid.Rows.Count; i++)
//Hiding the column
childGrid.Rows[i].Items[3].Column.Hidden = true;
//changing the readonly property to Textbox
(childGrid.Rows[0].Items[2].FindControl("Band_TB2") as TextBox).ReadOnly = false;
else if (WebHierarchicalDataGrid2.GridView.Rows[1].HasRowIslands)
ContainerGrid childGrid = this.WebHierarchicalDataGrid2.GridView.Rows[1].RowIslands[0];
childGrid.Rows[i].Items[1].Column.Hidden = true;
(childGrid.Rows[0].Items[2].FindControl("Band_TB3") as TextBox).ReadOnly = false;
regards,
hsakarp.
Hello Prakash,Please let me know if you have any further questions regarding this issue.
Hello Prakash,On which event you are trying to do this. If it is RowIslandsPopulating you can directly get it through e.Row.Items[i]. Otherwise as far as I can see you are getting the parent row with this.WebHierarchicalDataGrid2.GridView.Rows[0]. And its enough to add just “.Item[i]” in the end.
