Hi there,
I have an requirement to built 100% Stacked Bar Chart using infragistic .Net Control.
Infragistic do have that chart in place? If Yes can anyone guide me how to build that chart?
I have attahced the chart screen shot which we have implemented using SSRS reports.
Waiting for your reply.
Sanjay
hi mike.. what if i want the percentage displayed based on the total values entered?
Hi Mike,
I appreciate all the helps you have provided so far. I have recently come across the requirement for bar chart which goes like this. I have numbers instead of percentage and when we show data on bar I have to show perecentage and when I hover over it should show the number.
I have attached the screen shot also.
I'm not sure how I can do that. Please let me know how it can be done.
Thanks,Sanjay
Hello Sanjay,
Thank you for the update. I have created a new case for this ColumnChart questions you have. You can access your support cases by going to the following location and logging in:https://ko.infragistics.com/my-account/support-activity
For applying a gradient to the chart please see the following documentation:http://help.infragistics.com/NetAdvantage/ASPNET/2012.1/CLR4.0/?page=Chart_Apply_a_Gradient_Effect_to_a_Primitive.html
Please let me know if you have any questions concerning this matter.
Sincerely,Mike P.Developer Support EngineerInfragistics, Inc.www.infragistics.com
Thanks for all your support.
I have couple of question though 1) I'm trying to do the same in ColumnChart but not able to figure out. 2) How can I have gradient effect for the colors?
Thank you for the update. Since the bar/stacked bar chart don’t have data for the y-axis it seems the way to do this is using the margins on the y-axis, please see the following documentation:
http://help.infragistics.com/NetAdvantage/ASPNET/2012.1/CLR4.0/?page=Chart_Axis_Margins.html
For the Legend I adjusted the SpanPercentage of the Legend property and it allowed the items to be displayed on the same line. You could also use the FillSceneGraph event to modify the legend:
http://help.infragistics.com/NetAdvantage/ASPNET/2012.1/CLR4.0/?page=Chart_FillSceneGraph_Event.html
