Hi!
I am checking this sample:
http://ko.infragistics.com/products/aspnet/sample/data-grid/clipboard
Using IE I am able to copy/paste data from and to Excel.
In Chrome: I am able to paste from Excel to the grid. I am *not* able to copy data, it displays an alert message saying: This browser does not support copying/cutting in Java Script. Please consider an alternative copying routine.
Thanks!
Fernando
Hi
I am having the exact same problem in Chrome, and it is 2 years later. Is this an Infragistics problem or a Chrome problem?
I have tens of thousands of external users of my site. I can hardly ask them to install some sort of Flash thing in case they use Chrome as their browser. And I am very reluctant to install any horrible Flash stuff in my web application to accommodate for this.
Is there a solution?
Regards
Rob
Hi Fernando,
I'm just checking if you have solved your issue.
This is a known issue and a possible workaround you can find on this page in "2011 Volume 2" section below the line "Example: Accessing the clipboard using a Flash object" - http://help.infragistics.com/Help/NetAdvantage/ASPNET/2011.2/CLR4.0/html/Known_Issues_Known_Issues_and_Breaking_Changes.html.
Let me know if you have any further questions.
