I would like to invisible the expansion indicator, is any built-in properties there?
Thank you for reply i will check it out and let you know...
Setting the CollapsedDirection property off the SplitterPane to None should cause the expand/collapse indicator not to show.
Yes , I should not allow them the panel to expand when ever it is double clicked...
??? you mean the left right arrows? and are you saying you don't want to allow them to collapse it?
