I am using the WebDataGrid and I need to have a numeric editor for the first cell in a column and a percent editor for all other cells in that column. Is there a way to do that? I am using version 11.2.20112.2086 and VB code behind.
Hi Peggy,
Thank you for your replies.
Glad that your issue has been resolved.
Please do not hesitate to contact me if any further questions regarding this matter arise.
Never Mind :) The databinder syntax above does work. Stupid user error - I was looking at the wrong data. Thanks for your patience!
I've tried setting the value of the controls to Value='<%# DataBinder.Eval(CType(Container, Infragistics.Web.UI.TemplateContainer).DataItem, "fieldx") %>' but it doesn't work. Is the syntax different if I'm using a master page?
I am using the WebNumericEditor and the WebPercentEditor as the two controls in the templated column. How do I set the values of those controls to the value in the underlying data table that is bound to the grid?
Thank you! That works very well for what I need.
